Command admins or dispatchers are able to build out their own loads inside of the Command system.
Start by clicking on the Dispatch module at the top of the screen then Loads dropdown and then My Loads.
Next, click on Add New Load in the upper right-hand corner.
Enter all pertinent load information (Customer, Pick-up, Drop-off, Load Info, as well as any Documents) and a preview of the route will display to give you an overview of the where the driver will be going.
Click Save and then the system will ask if you would like to assign a driver to this load from your list of available drivers.
Select the driver from the list and click Assign.
The driver will receive a text message as well as an in-app notification letting them know they have been assigned a new load with a link to access the load inside of the Trucker Path app.
Questions?
Comments
0 comments
