The Settings section has for tabs:
Basic Info - Edit basic information about the fleet, add/manage drivers, operators & terminals.
ELD - Integrate your ELD with Command.
Load Sources - Integrate a supported Load Board with Command.
Customization - Change the look and feel of Trucker Path app for your fleet.
Subscription & Billing - Add additional drivers/operators, manage account and payment settings.
Basic Information
If you hold admin/operator status, you can edit your personal information in this tab. Note that only the admin user can edit company information and add/remove operators. Terminals are useful if you want to categorise your drivers and operators based on a region, operation, etc.
ELD Integration
If you are already using an ELD for your fleet, integrating it with Command lets you import driver/asset information into Command and improve the accuracy of your drivers' location. We currently accept KeepTruckin, Samsara and Trucker Path ELD Integration. We've included a guide for each system to help you connect successfully.
Load Board Integration
Once you integrate a load board into Command, you can search for high-paying loads and import loads all on one platform. We currently support Truckloads load board, with more integrations on the way. You will need to add your Email, Contact Number and DOT Number to complete the process. If this information was already entered in your profile, then our system will automatically fill this information. Once integration is complete, users can search for loads immediately. Save a load to view later, or add import the load into your own list.
Customization
The customization tools let you change how drivers in your fleet see the Trucker Path App. The Splash Screen content to suit your company's image, while the Forum Setting lets you add a link to a website.
Comments
0 comments
